Wiper Help Needed - NCRS Discussion Boards
Wiper Help Needed
  • Larry S.
    Infrequent User
    • September 30, 1979
    • 14
    Wiper Help Needed
    I purchased my 1995 Corvette used and Bubba had worked on my wipers and I need some help.
    What is the length of the refill blade (rubber)???
    Is drivers side and passenger side the samde length???
    Is "Bosch" or "AC Delco" embossed into the blade supports(metal)???
  • Tom H.
    • December 1, 1993
    • 3440
    Re: Wiper Help Needed
    Hi Larry !
    I usually have a 95 around here that I could look at for you. Today I don't. 94 used the same part number for left and right blades. 95 and 96 used different part numbers for left and right. Parts system does not specify length. There may be a slight difference in length, but I don't have a new set of blades in stock or a 95 to look at right now. Sorry I can't help more.
    Tom
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Gary S.
      • July 31, 1992
      • 1628
      Kind of a work around answer but if you are only looking for suitable refills, Advance Auto and Auto Zone have small computers at the wiper blade section. Input your information and it will tell you the length of the refills.
      Gary
      • Joe O.
        • November 9, 2006
        • 2
        You can also look in the owners manual (towards the back) and it gives a listing of all replacable items like wipers, bulbs, etc.
