I am replacing the pasenger side rear wheel bearing and have read a lot about the bearings, and the spacer. It seems that a spacer should only be used if the bearing is 0.9" wide. And its not used if its 1" wide. My new bearing from Corvette Central is 1" wide - but when its fitted there is about a 1/16" gap between the bearing and the flange plate that holds the bearing/spindle in place. Hence the spindle can float in/out by the 1/16" Is this normal?? If not what am I doing wrong? Is the flange plate damaged?
Help?? oh and thanks.
Mark
Mark
