'67 glove box door refinish - NCRS Discussion Boards
  • Larry S.
    • March 11, 2007
    • 457
    When I bought my '67, I noticed that the glove box door had either been painted gloss black or had Armor-All on it. I thought if it was Armor-All, it would eventually lose its sheen. Well, it hasn't, so I assume it's gloss paint.
    Should I wipe it with lacquer thinner, then spray it with Krylon 1613, and hope it doesn't bubble, or completely strip it before repainting? Is there an almost flat clear coat that would work? Any other tips? The glove box door is original and otherwise perfect.
  • Paul H.
    • September 30, 2000
    • 678
    Re: '67 glove box door refinish
    My 65 glove box door was exactly as you describe yours. I wiped it down with lacquer thinner then scuffed it lightly with a scotch pad. I then wiped it down with a moistened microfiber towel and let it dry. I then masked it off and gave it a couple of light coats with the Krylon 1613. It came out great and it still looks great after a year. Have fun
