Oli Pressure - NCRS Discussion Boards
Oli Pressure
  • Dave C.
    • March 1, 2004
    • 82
    Oli Pressure
    I have a 66/427 with the original 80 psi oil pressure gauge. The engine was replaced in 91 and rebuilt in 2000 but is a 427 with hyd. lifters. When driving cold, the oil pressure gauge is almost pegged at 80psi. After warming up it will drop to around 60 psi. Is this too high? I don't recall it ever getting that high before. What would cause this? by the way...Mobil 1 - 10W30
    • 15610
    Re: Oli Pressure
    I believe your oil pressure is normal as all the early big blocks in Corvettes had a 55-60 psi relief spring and an 80 psi gage.
    Mobil 1 10W-30 is formulated for modern engines and is not a very good choice for vintage engines.
    • Dave C.
      • March 1, 2004
      • 82
      Re: Oli Pressure
      Duke, What oil would you suggest for a 1991 crate engine rebuilt it 2000?
        • 15610
        Re: Oli Pressure
        API service category CJ-4 or CI-4 in a viscosity range suitable for the lowest anticipated cold start.
        • Dave C.
          • March 1, 2004
          • 82
          Re: Oli Pressure
          Duke,
          Isn't CJ-4 oil for Diesel engines?
            • 15610
            Re: Oli Pressure
            Yes, isn't your crate engine a diesel?
            P.S. Have you read the most recent issue to The Corvette Restorer - the article titled "Engine Oil for Vintage Corvettes"?
            • Dave C.
              • March 1, 2004
              • 82
              Re: Oli Pressure
              I have the article, just haven't had time to read it. You wrote it, correct? I take it will shed some light on the subject.....
                • 15610
                Re: Oli Pressure
                Yes, I wrote it, and the article and Web references should shed some light on the subject.
