1963 Undercoating - NCRS Discussion Boards
1963 Undercoating
  • Millard B.
    Infrequent User
    • March 1, 2006
    • 8
    1963 Undercoating
    This is probably a question that's been asked many times but I'm new. I purchased a restored 1963 SWC last fall. I've driven it less than 200 miles and already have one star on the right front fender from a rock hitting from beneath. I've been told 63s were not undercoated and I'd get a deduct when it's judged. Is this true and, if so, how big a deduct could I expect. I'm having trouble enjoying the car; keep listening for another ding in the paint.
    Thanks ...
    MILLARD L. BROGAN
    14202 Verde Mar Lane
    Houston, TX 77095
    (713) 817 1235
  • Joel T.
    • April 30, 2005
    • 765
    Re: 1963 Undercoating
    Millard;
    I have no idea as to an undercoating deduct... Personally, I would not do it, regardless. I too have a 63 SWC which somebody painted black on the bottom... just paint , no undercoating.. the stuff which is typically in the engine compartment... I guess they just got carried away! I've driven the car a couple of thousand miles and have never experienced what you have described... a pebble or small rock for that matter being tossed up from underneath should not damage the surface.
    I had a C1 a few years back and had the (pressed on) vibration damper let go while I was driving and that did no damage (on that one I was lucky I suspect).
    I'm sure you will get a number of other responses from the guys on the board...
    Joel
    • Boyan B.
      • August 31, 1999
      • 187
      63's had undercoating, but it was limited. Usually just the top of the wheel wells. I would undercoat this area, where your rocks are being kicked up. The deduct, would be 1-2 pts, if any. You will loose more if you paint is cracked. Undercoat just what you need and enjoy driving the car.
      Boyan
      • Stan E.
        • April 30, 1991
        • 383
        There is a good discription in the judging guide.
