I have a 66 327/300 4-speed with an April build date. Engine and trans are out of the car and I'm in the process of getting everything back together. Installing new clutch, clutch fork, ball stud in the bellhouseing, etc. The clutch is Delco OEM. I bought a new clutch fork rod because there was a lot of ware on the end that attaches to the cross shaft. My old rod is 9" from fork end to inside of the bend. The one I bought is 10 9/16" to the same point.
My question is the length of the old fork rod. All the reading I've done in the archives say it should be 8 1/2 or 10 9/16 with 10 9/16 for late 66 years. Any ideas what the 9" rod is? Everything worked well before this project and it sure would be nice not to have clutch adjustment issues. One other point. I'm replacing the CE 327 that was in the car originally with the correctly dated 327/300 engine. I don't know if I should keep the longer rod and try it or get the shorter rod. I'm about 2 weeks from starting this engine up. What are your recommendations? I really don't know what to do now.
) endured in my '65 396 -- was one of the first parts I replaced in late '80s.
