Tach Question -L72 - NCRS Discussion Boards
Tach Question -L72
  • Larry S.
    • September 19, 2007
    • 204
    Tach Question -L72
    I have a 1966 L72 BB and wanted to attach a portable tach (dwell-tach tester) to assist me when checking the timing curve. The car has transistorized ignition. I connected the red cable from the tach to the coil "-" (smaller wire) connection and the black cable to a good ground (as suggested in the dwell-tach manual) but the tach doesnt work. I tried a second dwell-tach tester, and it doesnt work either. What am I doing wrong??? Thanks for any help on this.
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: Tach Question -L72
    Hope someone will help you today. I too have an old tach/dwell meter and wonder what I can use it on today. I have Pertronix Ignition conversion.
    Stu Fox
    • Larry S.
      • 204
      Yes Stewart,
      I am not sure if I connect the tach (red clip) to the negative terminal on the coil (the same way that I connect it on a points-condenser distributor) or somewhere else as the distributor is transistorized. Thanks for your comment.
        • 15610
        IIRC when I had a TI on my car, my ancient mid sixties vintage tach/dwell meter functioned with the standard connections.
        Make sure you have a good ground - measure resistance between your test ground and battery negative post to make sure it's zero.
        I know my old test tach works on the HEI, which has a simliar primary current wave form to the TI.
        • Larry S.
          • 204
          Thanks Duke, I will check it out as you suggest.
