66 L-72 Rpm... - NCRS Discussion Boards
66 L-72 Rpm...
  • Larry S.
    • September 19, 2007
    • 204
    66 L-72 Rpm...
    I want to check the timing on my big block and need to connect a tach test-meter to aid with adjustments. Thing is, it has the GM original transistorized ignition and I am not sure if I connect the tester the same as if it had a points-condenser ignition? Any body have any suggestions?
    Thanks.
