1966 Power Brake Master Cylinder - NCRS Discussion Boards
  • Tony C.
    • February 29, 2008
    • 117
    Hi
    I am looking to find out what type of nut holds on the power brake master cylinder to the booster. The set that came with the car looks like a repro and has a washer cast in to the nut.
    Thanks Tony
    Re: 1966 Power Brake Master Cylinder
    Tony -
    It's a plain phosphate-coated 9/16" hex (3/8"-16) nut with a phosphated split lock washer; same as the nut that secures the outboard end of the clutch cross shaft to the frame bracket.
