I've looked through the archives and haven't found a definitive answer to the late '69 427 heads question.
Reason being I have a late 11/22/69 427 L68 car in which someone "improved" it with --840 435hp heads. I have been looking for a set of correct 3931063 oval port heads with a casting date close to my block of J-22-69 (10-22-69). AND they don't seem to exist cast that late...
Seems like all the heads cast after July of 69 are 3964290 castings which is the exact head with taper seat plug threads.
Now my question... I've seen many instances of late '69 cars with this head discussed on this board. Many have stated that these heads were probably used on late '69 cars as Tonawanda ran out of 063's. Many have also speculated that they would be machined with the old flat seat plug threads if for a Corvette. Has this been documented? Has anyone seen 3964290 heads with flat seats? I would really like to find a set of correct heads for my car but 3931063 cast this late are non-existent, and 3964290 with old style plugs are just as elusive! Any comments or suggestions???
Anyone out there with a car of the same date range that could tell me what their car has would be fantastic!!!
Thanks in advance!
Thanks in advance!
