68-70 alarm switch w/ B&S key - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    I have a Briggs & Stratton alarm switch that I think might be for 68-70 Corvette. Can someone describe to me how the key is supposed to function on this switch? The key inserts with the plane of the key vertical and then the key can be turned 90 degrees clockwise. But in the clockwise orientation the key does not come out. Does one activate the switch by turning it 90 degrees clockwise from vertical and then back to vertical? And then does one de-activate it by performing the exact same motion again? Or does the key behave differently in the switch when the switch is not energized? I'm definitely confused.
    Gary
    Northern California chapter
  • Nick M.
    • September 30, 2005
    • 143
    Re: 68-70 alarm switch w/ B&S key
    A related question for those who have a similar accessory. I have the same key switch on my 69 but have no key for it. If I remove the lock, can a locksmith make a key for the lock or do I need to replace this original part with a repro lock and key assembly?
    63 FI SWC, Top Flight 2006/2008, PV 2007
    69 Coupe, 427, 400HP w/AC
    72 LT1 Targa Blue Convertible - Duntov Award
    07 Z06, Black/Black - Daily Driver
    • Gary B.
      • February 1, 1997
      • 6979
      Nick,
      Keys for some locks, like tire locks and glove box locks can be made using the impressioning technique. I don't know if the alarm lock cylinder is one that would permit that technique or not, but it's worth asking an old-school locksmith.
      Gary
        • 15573
        • Harmon C.
          • August 31, 1994
          • 3228
          Gary
          I would say the lock has a problem and the key should come out in the ninety degree position. This is the way a later alarms works with a GM key but I have not had a switch like yours but with no replys this may help. Hook a test light to the back and see how the switch works. If it just an on-off type the key needs to come out..
          Got a phone call so this is a little late and Terry put in a post.
          Lyle
          • Michael B.
            • June 18, 2007
            • 400
            The key should come out at both ends of the rotation. These are available from Corvette Central part #503060 for $30.
            • Gary B.
              • February 1, 1997
              • 6979
              Thanks everyone; I must have a dud
              All,
              The NOS switch I have must be faulty. My switch looks exactly like the switch in Michael's photo. There is electrical continuity between the terminals when the key is rotated clockwise, but the key will not come out in that position. Only by rotating back to the counter-clockwise, non-continuity position can the key be removed.
              Thanks all for the help,
              Gary
              Northern California Chapter
              • Gary B.
                • February 1, 1997
                • 6979
                A final update: probably not a faulty switch
                Guys,
                After talking with a locksmith, I believe the NOS switch I have is not faulty. As Terry M. suggests, it just isn't correct for 68-70 Corvette. Some newer alarm switches have a "momentary" design, i.e., rotating the key clockwise and then back counterclockwise produces a momentary pulse to a control board that turns the alarm on and off each time the two-way key turning cycle is performed.
                So, if you see a switch for sale at a swap meet, make sure you check to see that the key can be removed in both the fully clockwise and the fully counterclockwise positions. If it can't be removed in both positions, it's one of the newer momentary designs and not correct for 68-70 Corvette.
                Gary
