69 quarter panel lip - NCRS Discussion Boards
  • Brad S.
    • July 31, 2005
    • 227
    On my 69 coupe there is a lip on the front edge of the quarter in the door jamb. On the passenger side the lip goes up the vertical surface and continues to the 3'' horizontal surface on the top edge of the jamb. On the drivers side the vertical lip does not protrude as far and is not there at all on the horizontal top section. Was this lip used to adjust proper door fit?
  • Terry B.
    • August 31, 1999
    • 607
    Re: 69 quarter panel lip
    Brad,
    I'm trying to visualize what this looks like but if you could add a picture I think it would help. Could this be a water draining channel?
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • Brad S.
      • July 31, 2005
      • 227
      Terry the first and third pictures are of the passenger side the middle picture is of the drivers side . You can see the lip on the passenger side but there isn't one on the drivers side. It is hard to get a good angle to show the lip on the first and third pictures. Thanks Brad
      • Chuck S.
        • April 1, 1992
        • 4668
        I know exactly what you're talking about, and I believe you've nailed it, Brad.
        I expect they might have fine-tuned the door gap by grinding that lip...at least when it was available. That's how I plan to use it. But...I doubt that any assembly efforts were made to create that panel "overlap" beyond what was designed in by engineering. It's the result of tolerance combinations in the body assembly jig and panel dimensions IMO.
