Correct numbers for '66 427/390 tranny? - NCRS Discussion Boards
    Re: Correct numbers for '66 427/390 tranny?
    Originally posted by Wayne Midkiff (3437)
    [ADMINISTRATOR -- I tried to load a pic that I had already used in a previous post and it will not allow the same pic for a different thread --- WHY ?]
    Wayne - If John doesn't see this, I'll comment. That's a "feature" of the new vBulletin software, probably to keep the server from loading up with duplicate copies of the same photo - we have the same software on the VH board, and it does the same thing. You can get around it by re-sizing and re-naming the image when you want to use it again - that way the server won't recognize it, and it'll upload. PITA. I usually just upload the image to my Village Photos account and link it in full-size for the second usage.
    • Tony S.
      NCRS Vice President, Director Region VII & 10
      • April 30, 1981
      • 969
      Hi Joe. I'm trying to run down the tranny numbers for a '66 L36 with M21 and a 3.70 (FA) rear end. I started the thread needing:
      1. main case no.
      2. side cover part no.
      3. tail housing
      and then realized I need:
      4. the metal tag no.
      Didn't mean to confuse.
      Tony
      Region VII Director (serving members in Arkansas, Kansas, Louisiana, Missouri, Oklahoma and Texas).
      Original member of the Kansas City Chapter, est'd 07/11/1982.
      Member: 1965 and 1966 National Judging Teams
      Judging Chairman--Kansas City Chapter.
      Co-Editor of the 1965 TIM and JG, 6th and 7th editions.
      • Tony S.
        • April 30, 1981
        • 969
        Tony -- all '66-7 side COVERS had CASTING #3884685, as does this one on trans from '66 Corvette # 14095.
        But the steel tag attached to the lower forward sidecover bolt will be stamped 3880855 if ratio 3.08 - 3.55, and 3880853 if 3.70 or 4.11.
        Thanks! That's the info that I needed to know. I wish some of the brain trust in this forum could be added to updating the '66 JG. The current edition of the '66 JG is no help at all when it comes to tranny info.
        Best,
        Tony
        • Ron E.
          • July 16, 2007
          • 7
          Hello. I have an early 66 L36 car with the wide ratio M20 and 3:08 gear. What should the metal tag number be for this? Thanks for the help and interesting discussion above, Ron.
            • 43193
            Ron-----
            I believe it should be GM #3870354. It's also possible it was GM #3870357.
              Best,
              Tony
              Tony -
              Probably because axle and transmission "numbers" aren't judged in Flight judging (only in Star/Bowtie judging).
