Re: Tip-In Stumble
Timothy,
Accel pump cam is in the #1 hole. I've never tried it in the #2 hole, but I'll do it today. Somehow I don't think that that's going to change things, either. I'll keep you posted. If one squeezes the throttle slowly enough, then accelerator pump should not squirt, correct. That's the situation where the lean pop occurs. I swapped in the stock .025 nozzle and car runs exactly the same, so they'll stay in place. I do not think that the accel pump shot is the culprit.
You might be right about the jets. I have stock jets (65/76) all around. Plugs burn light tan insulators. Dyno pull from 2 years ago shows A/F ratio @ WOT between 14.5 and 15:1, until the secondaries open, where it drops to 12.0 and slowly climbs back to 13:1 @ about 5300 RPM (see attached). I'll try 67's and 69's today.
Only one more idea (besides the pump cam and pri mains) that I have left. The far flung possibility that there is a problem with the emulsion tubes in the pri metering block due to a defective casting. Idle and main air bleed orifices are stock, never drilled, free and clear with compressed air and/or Gumout.
I reworked my distributor's advance map, by limiting max centrifugal advance to 21 degrees by modifying the advance weights, all in @ 2200 RPM. I have initial set @ 16 degrees, for a total @ WOT of 37 degrees, all in @ 2200. Vac can is a 236, verified to be fully deployed @ 17 degrees at about 8 in-hg.
Timothy,
