Much to my chagrin and embarrassment, I have put a scuff on the edge of the polish chrome wheel on my '05. The scuff is about an inch and one half long along the edge of the wheel where it meets the tire. I am hoping that there may be a way to buff out the scuff. I haven't dealt with a problem like this before, so I would appreciate some advice. Thanks. Dave
Wheel Scuff
Re: Wheel Scuff
there is no way to remove the scuf as the wheel must be refinished. try these people or someone like them. http://www.wheelcollision.com/index.html . i understand most dealerships have a contact in the area that can refinish the wheelsMuch to my chagrin and embarrassment, I have put a scuff on the edge of the polish chrome wheel on my '05. The scuff is about an inch and one half long along the edge of the wheel where it meets the tire. I am hoping that there may be a way to buff out the scuff. I haven't dealt with a problem like this before, so I would appreciate some advice. Thanks. Dave- Top
Re: Wheel Scuff
not personally as i have never scuffed a wheel BUT several people i know have used them with good results.- Top
Re: Wheel Scuff
David-----
One can do a pretty good job "erasing" small curb scuff marks from an ALUMINUM wheel. It takes care and "finesse" using very fine grit wet and dry sandpaper to remove the scuff. Then, after polishing the sanded area, apply clearcoat which is available in spray cans. It won't appear like it's never been touched, but, if done with enough care and patience, it will be about 90% improved.In Appreciation of John Hinckley- Top
Re: Wheel Scuff
David-----
With a CHROMED aluminum wheel, there is no option but to have it professionally re-finished. I would not be surprised, though, if it costs more than $200.In Appreciation of John Hinckley- Top
Re: Wheel Scuff
I deal with wheel refinish people every day . if is small I would live with it. touch it up with some clear so it wont turn black. You wont be happy with a high polished refinished wheel .& i have seen lots of them....Bill- Top
Re: Wheel Scuff
Joe, thanks for the tip. While the "rash" appears to be fairly superficial, I was not sure if it would be possible to smooth it out without making the situation worse. It sounds like your idea is worth a try. Again, I appreciate your expertise. Dave- Top
Re: Wheel Scuff
Thanks, Bill. It does worry me that the fix may be more noticeable than the scuff. It is always tough to know what to do. Unfortunately, I am the type where these things really bother me; especially, when it is due to my own carelessness. It sounds like you have had some experience with this....thanks for your input. Dave- Top
