Knock off wheel center cone dimensions...Repro, DBKO,and OE - NCRS Discussion Boards
  • Jim V.
    • November 1, 1991
    • 587
    Looking for height, and upper and lower diameter measurements on DBKO and KH KO wheel center cones.
    Repro Knock off wheel cones seem to measure
    1 15/16" Height
    6 7/8" Lower OD
    4" upper OD.
    Curious what the dimensional differences are, if any, between; 1) repro KO, 2) repro DBKO's, and 3) KH KO cones.
    JimV
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: Knock off wheel center cone dimensions...Repro, DBKO,and OE
    1 15/16" Height
    6 7/8" Lower OD
    4" upper OD.
    JimV
    Jim -- not sure what your acronym DBKO means, but I'll guess at direct bolt-on knock-offs (?).
    Anyway, I've got a set of '66 originals with the cones still on the wheels, which makes it difficult to measure height and base diameter. My best efforts are: upper OD = 4.05" (caliper); height (depth caliper) 1.96" to 1.99"; lower OD = 6.92" (measured circumference with thin wire, then adjusted for error of wire size).
    Also have a set of Western Wheel Corp -- K.H '64-65 repros, probably circa 1987: upper OD = 4.035; height = 2.03"; lower OD = 6.78" (using same measuring methods as above, as these cones are also on the wheels).
    • Jim V.
      • November 1, 1991
      • 587
      Wayne, yep...DBKO is direct bolt knock off.
      Interesting that OE and Repro appear to be dimensionally equivalent.
      Still looking for somebody with the DBKOs.....
      Thanks Wayne!
