Having trouble with the doors on a roadster. the bottom of the passenger door is out about 1\8th of an inch. The fit is good everywhere else. It was not like that before. I've had them that need to come out before but not where they need to go in. No work has been done on the door and no shims in bottom and one on top.
Any suggestions.
thanks
Any suggestions.
thanks
If the door fit before and you didn't do significant bodywork then it should fit again. Try moving the hinges to different locations. You may find that you'll need to shim appropriately at the other locations. Not all hinges are EXACTLY the same..... I had a similiar problem, except I only had to determine the shim count. Kept track of the shim count when I disassembled but lost track of the hinge location... not good
