C2 Repro Tire Sizing and Source - NCRS Discussion Boards
  • Dave B.
    • May 31, 2006
    • 52
    This is a new post of a question I listed yesterday along with a query about repro tire vendors:
    First:
    There have been several discussions about the current repro bias ply tires not fitting the spare tire tubs. I was recently made very aware of the issue when I purchased a 775x15 Firestone which would not fit. Yesterday I picked up an older repro at Carlisle which fits fine. The diameter difference between the two tires is an inch - I can't believe it!
    My question to this board is if I purchase the current repros that are available for driving and judging purposes, will I run into an clearance problems on the car itself - it's a '65 roadster.
    Second:
    I noted some posts that indicated problems with Coker repro tires. Are there any opinion on tires from Universal Tire in Hershey, PA - specifically Firestones.
    Dave Brown
  • Dick W.
    • 10483
    Re: C2 Repro Tire Sizing and Source
    Search the archives, but I think that you will find the Kelsey Goodyears the best tire for judging purposes.
    Dick Whittington
    • Anthony G.
      • February 1, 2006
      • 50
      Boy Dave, I wish I would have seen this earlier. I just picked up 4 Firestones from Coker yesterday.
      Tony Gray
      York, PA
      66 327/350 Convert.
      AACA Senior Award Winner Hershey 2009
      • Dave B.
        • May 31, 2006
        • 52
        Tony,
        When you get your tires mounted I would be curious to know the overall diameter. Per my original post, the first repro tire I had purchased which did not fit the spare tire tub was from Universal Tire. The overall diameter measured to the peak of the tread is 28 1/4". I have to believe all these tires are sourced from one factory somewhere and marketed by these various companies we recognize. I'd appreciate knowing your results.
        Dave Brown
        • Donald T.
          • September 30, 2002
          • 1319
          Dave,
          You shouldn't have any clearance issues on the car for any of the currently available repro tires. I have also had issues with repros fitting in the spare tire tub. However, the Goodyear Power Cushions seem to fit just fine. It's a snug fit, but no problems getting it in/out.
          Don
