Hi All;
I've started on rebuilding a distributor from my 1963.. Have all the parts which I want to replace on hand. I have everything apart and now need to remove the old bushings from the housing. I also have access to a shop press.
Question... What do you use to press the old ones out???
Second question... When pressing the new ones in, it would appear to me that the bottom goes in first and winds up flush with the base of the housing and then the top is pressed in... assuming to a stop of sorts in the housing.
Thanks!!
Joel
Thanks!!
Joel
