Can anyone advised on a good way of replacement method for the RH and LH.
The body is off and on Noland body dolly. The doors are still in place.
I have doner replacements for both sides which includes about a foot of the uprights. I also have the sleeves that I bought from Caladonia previously since originally I thought I would just put the sleeves in.
Looks like I need to raise the body about a foot off the body dolly to get at the channels. I was thinking of supporting the body on the fiberglass buckets behind the seats with a large sheet of plywood. Is there any good place at the front?
Next would be to cut out the originals. Should I align the door gaps by moving the body front and back before I do this so the body is somewhat straight?
I need to cut off about 1/2 inch of the bottom of the front uprights to get to good metal. The backs are fine all the way to the channels.
Next is to cut the front doner uprights to match the original uprights and cut off the back uprights completely on the doner channels.
Do I just but weld the front uprights and fillet the backs or is there some alignment step I need to do before welding to get the door gaps right?
Also, should I be bracing anything before I cut out the original channels(this is a coupe)?
I noticed on some of the vendor sites, that they say to do the welding after the body drop and after door gap alignment with the body shims.
Should I leave the tops of the original channels in place and cut out the sides of the channels. Then plug weld the doners onto the original. This is essential what they do with the add on sleeves.
Thanks for any help
Steve L
73 coupe since new
Thanks for any help
Steve L
73 coupe since new
