I have not had a chance to do any trouble shooting yet, but here are the symptoms:
1. Squeal sounds just like disk brake noise, but it's not, because it comes from the motor when the car is stopped (or moving)
2. Only starts doing it after more than 30 minutes of driving
3. Pitch DOES NOT change with RPM
4. Starts and stops. Not constant. 5 seconds on, 2 off, 10 on 5 off,etc
5. Did this several months ago the last time I drove more than 30 minutes. Since then I have driven at least 3 times a week on shorter trips and it has not happened. Until yesterday when I drove more than 30 minutes.
6. Car still has the AIR pump and has PS. But the noise sounds like it is coming from more toward the center of the motor.
Any ideas? Could I be hearing a Vacuum leak? The first time this happened, I think the idle went down, too. Since then I raised the idle and it has stayed OK.
Any thoughts are appreciated
Rich Giannotti 38594
