Need to Find 65 Trico Wiper Blades - NCRS Discussion Boards
  • Michael S.
    • June 7, 2007
    • 82
    I have the correct Trico wiper arms and wiper holders but I can not find the correct blades. I need the 15 inch blades with the dots running the entire length and also with the patent numbers on them.
    Does anyone have a suggestion on where to buy them? I have looked on the Driveline ads and on E-Bay with no luck. Need them for final preparation for the Waco regional in October.
  • Edward S.
    • December 1, 1986
    • 514
    Re: Need to Find 65 Trico Wiper Blades
    I see them from time to time on e-bay, in the Driveline, etc. I am sure if you call Paragon they would have them and would ask big bucks. As always just depends how bad you want them. Good luck.
    • John S.
      • September 30, 1997
      • 263
      Original Trico blades have the dots and the Trico patent numbers right above the dots. Paragon sells blades with dots that you can cut to size, but no patent numbers.
      • Mark D.
        • June 30, 1988
        • 2142
        Pete Lindahl
        pclindahl@comcast.net
        Kramden
        • Donald T.
          • September 30, 2002
          • 1319
          They are definitely hard to find. I have managed to collect a few examples. They do show up on ebay from time to time. The last set of NOS blades and holders I saw was at Bloomington and the seller was firm at $500. Not sure if he actually got it, but it was too rich for my blood!
          https://www.forums.ncrs.org/attachme...68358&uid=1807
          • Bob J.
            • December 1, 1977
            • 713
            Michael,I think the correct term for what you are looking for is "wiper inserts", the holders (which you have) are called the blades. Bob
            • Michael S.
              • June 7, 2007
              • 82
              Bob, you are correct, I meant the rubber inserts are what I need.
              Mike
              • Michael S.
                • June 7, 2007
                • 82
                I talked to Pete a couple of times in the last 3 weeks. He said he would look for the inserts, but he never got back to me so I assumed he did not have any. He was probably busy at the time getting ready for Carlisle, so maybe I should try him again. Is Pete typically the best source for the Trico inserts and aren't there any other known suppliers.?
