The theft alarm has stopped working. Any door or hood open will not trip the alarm. I started at the rear key switch and it doesn't appear that I have power incoming to the switch. The wiring diagram shows the power switch is supplied with a connection, but doesn't offer as to where that connection is found. All fuses work. Questions are:
1. Where does the power for the alarm system originate from?
2. Is the alarm system fused, if so, which fuse is used?
3. Any help or suggestions on how to track the power sourcing through
the system?
I feel if I can ascertain that the system is getting power, I could track down any door or hood switch failures..........
Thanks to all in advance for sharing your knowledge/experience!!!
the system?
You can bench test it by placing it in a vice and using your 12v battery charger set on the low setting, often 1 or 2 amps. That is how I did it when I was checking out why the one on my 72 didn't work.
