Drive Shaft removal - NCRS Discussion Boards
Drive Shaft removal
  • Pat H.
    • December 1, 1996
    • 418
    Drive Shaft removal
    I'm try to remove the drive shaft from a well used T-10 in my 59. The shaft appears to be stuck in the tail of the trans. I have tied a cable to the drive shaft with a come-along, but it doesn't budge. I even tied to reattach the drive shaft to the diff. but it drive shaft is in too far to re attach. I have a rebuilt T-10 ready to install. Any suggestions?
  • Mike M.
    • May 31, 1974
    • 8365
    Re: Drive Shaft removal
    the yolk usually slides right off the tail shaft. only time i've had trouble with yolk removal is when too much torque/ too sticky tires/too numerically deep rear axle ratio was employed that resulted is twisting of the tail shaft on a full throttle launch. .re-attach the come-along then take a crow bar or similar tool and tap the yolk via the crow bar with a stout hammer.or call dennis clark and ask him how he removed the yolk from his twisted tailshaft at Palmdale in '93. mike
    • Dennis C.
      NCRS Past Judging Chairman
      • January 1, 1984
      • 2409
      Drive Shaft removal
      Think Mikie is on the right track. Possibly twisted tail shaft (which twists the teeth on the shaft). Rather than a come-a-long, I suggest a 5# sledge hammer to coax the yoke off the shaft. I know it's not a pretty picture, but may be the only solution. If others know of an easy, less violent fix, please step up. I'd love to hear it... Best, Dennis
