i use the holley 1850 carb with mechanical choke. i also use the k&m air filter with the drop configuration so i don't push anything through the hood. i notice that when i remove the air cleaner the choke plate is always a little closed, covering about 10-15% of the opening over the venturies. this happens even thought the choke cable is pushed all the way in. i have checked the cable function with the air cleaner off, and the choke plate opens and closes correctly and completely. i am stumped. any suggestions??
mechanical choke question
