Anyone know what this stuff is made up of ?
Sea Foam
Re: Sea Foam
When Used Thru Injection or Carburetor- Cleans carbon build up
- Cleans intake valves and pistons
- Gives smoother idle
- Cleans catalytic converter odors
- Cures hesitations and pings
- Restores power and pickup
- With warm engine running, SLOWLY pour 1/2 pint through carburator, throttle body or direct manifold vacuum line that will feed ALL CYLINDERS. Possible sources are P.C.V. valve or brake booster line. Turn ignition off. Restart engine after 5 minutes. Be sure exhaust is well ventilated. Fumes will be extreme for a short period of time.
- Spraying water does the same thing down the Carb!
- Top
Re: Sea Foam
This product is 100 per cent natural and environmentally friendly*
The Inconvenient Truth about its contents, or, its Guaranteed Analysis:
30%---------decomposed human protoplasm (all natural-100% autolyzed and/or putrefied)
30%---------decomposed marine fauna protoplasm
20%---------SSSSSSSnake oyl
10%---------chum residue
5%----------methane (all natural-derived from post-mortem bloating)
<5%---------flotsam and jetsam
TRACE-------human ejaculate (may be higher if harvested from Caribbean beaches)
* Al Gore approved
Actually, most of these products contain a very high percentage of garden variety kerosene and/or #2 fuel oil, with some aromatics tossed in fer good measure.
Iffen you wanna purge your engine of top cylinder deposits, a JUDICIOUS
application of Roy's method works quite well!
- Top
Re: Sea Foam
The Land Rover owner's forum is moderated by a retired service manager and he swears by seafoam for the Rover V8 (an old Buick design from the early 60's with cyl. sleeves). I have yet to try it on my old LR but a lot of the members there have done it and all of them say the truck runs much better.- Top
Re: Sea Foam
Bob Kunz recommended it for the tank after I had him do my carbs. I tried it and did it really make a difference.....................I really don't know but his rebuilds were great.Jack Corso
1972 Elkhart Green LT-1 Coupe 43,200 miles
Top Flight 1994, 2018 & 2021- Top
Re: Sea Foam
I pour transmission fluid down the carb while keeping the engine running. It makes a lot of smoke but seems to clean the inside of the engine well. You can tell by the better idle. Typically, I pour a quart through the engine before I drive it on the interstate for a few miles.- Top
Re: Sea Foam
I don't know what it is made of, but I use it as a winter fuel stabilizer in my caes and in my boats instead of Stabil. It has been recomended by several marine dealers as beter than Stabil. I bought a boat with a 150 hp motor that had been sitting for a couple of years. It ran OK at first but after a few hours of use it wouldn't idle. After a couple of cans of Sea Foam it started running better and has been for last 3 years.
Iuse it every fall as a fuel stabilizer.
- Top
