I have a restored 71' LS5 with a correctly restored Q-Jet with a very interesting problem, please bear with me as the explanation is lengthy.
First the carb works fine with the exception of the secondary air valve. When you floor the carb sometimes the air valve opens and the secondaries work as designed, shift gears and floor it and the air valve does not open. The bypass vacuum does not work therefore not allowing the air valve to open. Drive the car several miles and try it again and all works well again until you lift off the throttle to shift and no secondaries.
Sometimes they never work and then all of a sudden they work as designed.
Any and all help is needed. If you need more detail call me at 303-652-3185
Bill
Bill
