55 Rotor Trivia - NCRS Discussion Boards
55 Rotor Trivia
  • Roy B.
    • February 1, 1975
    • 7044
    55 Rotor Trivia
    Not all 55 owners realize the V8 Dist original ROTOR was different then the ones seen today. It was designed to help remove radio static.
    They can also be used in 56-57 to do the same thing. Don't look under the word Corvette ,Olds,Buick 53-55 and Chevy also used the same rotor and is cheaper and easy to locate or buy.
    What you find today L/ and R/Original rotor
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 55 Rotor Trivia
    Originally posted by Roy Braatz (182)
    Not all 55 owners realize the V8 Dist original ROTOR was different then the ones seen today. It was designed to help remove radio static .....
    Roy -- thought viewers might like to see a close-up of that original '55 rotor. Looks like some sort of resistor between the brass button contact and the copper (?) tip. Must have been expensive to manufacture.
    Can't find the older 1917249 # in any of my books going back to 1962. Was it discontinued before that ? Is the part # on the box of the replacement D-403 # 1927393 ? [It's partially hidden in your pic].
    Got this rotor on eBay in a lot of 40 small boxes of Delco ignition and gen./alt. stuff.
    • Michael L.
      • July 31, 2005
      • 562
      Re: 55 Rotor Trivia
      First time I've ever seen one of these!
      • Roy B.
        • February 1, 1975
        • 7044
        Re: 55 Rotor Trivia
        The rotor has long been discontinued, it's a piece of carbon that helps reduce static. The rotor is for a V8 not a 6. Like I said easy to find under Olds or Buick , Corvette people mostly don't know or are concerned if a part is not judged.
