I have an AIR pump with no numbers stamped on it--was that way when I purchased it but inside when it was rebuilt by B. Hodel it said 1973 (has black plastic centrifugal filter). The pulley that was attached to it# is 3927116AU. I will try to post pictures of the manifold tubes--does anyone know what they look like for a 1973. Trying to figure out if they are all the same year. Bought them along with other parts for my 71 and then found out they were incorrect.
AIR pump, Pulley and manifold tubes. What year?
Re: AIR pump, Pulley and manifold tubes. What year?
Paul-----I have an AIR pump with no numbers stamped on it--was that way when I purchased it but inside when it was rebuilt by B. Hodel it said 1973 (has black plastic centrifugal filter). The pulley that was attached to it# is 3927116AU. I will try to post pictures of the manifold tubes--does anyone know what they look like for a 1973. Trying to figure out if they are all the same year. Bought them along with other parts for my 71 and then found out they were incorrect.
The AIR manifold tubes assemblies ("trees") were exactly the same for 1971 LT-1 and all 1973 small block. These are the "crimped" style tubes with smooth, "blackish" organo-phosphate or "black zinc" finish. The left side was GM #3905297 and the right side was GM #3877480. The left side tube was also used for all 1967-72 small blocks with AIR and the right side tube was also used for all 1966-72 small blocks with AIR.
The external configuration of the 1971 LT-1 AIR pump and the 1973 AIR pump are identical except for, of course, stamped numbers and, possibly, the centrifugal filter ("fan") color. 1971 definitely used the "white" centrifugal filter. I think that by 1973 the black filter was in use. Otherwise, though, the pump configuration is the same for both years.
Both 1971 LT-1 and all 1973 with small block used AIR pump pulley GM #3917234 in conjunction with pulley spacer GM #3933185. The spacer is 3/4" thick and is installed between the pulley and the pump hub.
The GM #3927116 pulley was used for many 1968-69 passenger, Chevy II and Camaro applications and also a few 1970-75 applications. However, it was not used for a Corvette application.In Appreciation of John Hinckley- Top
