Re: Best advice -L-36 blue smoke -rebuild time??
Keith - I think your diagnosis is on the mark. The diagnostics indicate a possible ring problem in #3. The other cylinders look basically okay.
The next diagnostic test to conduct is a bore scope inspection of #3. Most good mechanics have a flexible tube bore scope that can be used to inspect the cylinder walls with the piston at BDC, and the spark plug hole orientation may allow the use of a cheaper rigid tube borescope.
If there are no significant score marks, then the problem could be a "sticky ring", which is not unusual for a 40 year old low mileage engine, especially if it sat a lot with dirty oil!
Sometimes sticky rings can be "unstuck" with a good detergent package like in C-category oil, and there are some oil supplements that have even more detergent that can be used to aid the process. The Bardahl product you added might be such a product.
With a crankcase full of detergent, get it hot, and drive it hard, and the ring may unstick itself.
I think you should follow this course for some time rather than tearing into an original low mileage engine.
If you live in my neck of the woods I would be glad to help out with "Italian Tuneups" as I know of plenty or roads to give a car a helluva workout, and I have logged a lot of racing and track time events in the last 45 years.
) that I seek out a professional "hot-oil flush" for my 66. I'm told a local dealer has a very high power Snap-On oil flush system that he believes in, others have told me it will do more harm that good. Not sure about that now that I have learned I have a real problem at # 3.
to do this engine right.......sure wish I was more mechanically inclined........back to you......and thank-you again. K
