cast # 3840383 what year is this this housing? Will a 10.5" pressure plate fit this housing? I have a Feb 64 built dated car. I have a 411 posi. with a 4 seed Muncie trans that matches the posi. Said in the NCRS tech guide cast # 3858403 is correct for a Feb 64. However If the production line is out of the 403 will the 3840383 have worked? Before I switch this one for a 403, I want to make sure it was not the original with the car. It looks as those it was!
Sam
Sam
]. Now this conflicts with the '65 TIM&JG which claims (typical) mushroom heads on all 3770529 blade assemblies (ie. all cars except C60 and L78). So did they start flat head rivets in latter '64 MY, then switch back to round heads in '65
