I just replaced the gas/temp gauge in our 57. After getting it all hooked up, the gauge stayed on all the time, even with the key off. Checking the wiring this is what I found. The hot wire, pink, goes from the gauge into the loom. Two pink wires come out of the loom and are together in one connection that attaches to the ignition switch. The second pink wire comes out of the loom and to the fuse box. This all matches the wiring diagram. Problem is, the pink wire is attached to the top right fuse which is hot all the time. If I disconnect that wire, then the gauge works properly. There are only 2 wires on the fuse box, this one and a red one that is hot all the time. (no heater) I cannot find a diagram of the fuse box to determine which fuses go where. The assembly manual shows a couple of individual lines, but nothing shows it all. So, where should this pink wire go and what happens if I leave it off?
Ken 38732
Ken 38732
