I'm considering the purchase of a 63 and I'm concerend with the VIN tag placement. It's spot welded several times on each side, and is placed right up against the Trim tag (no space between them at all). Can anyone verify the authenticity of this placement?
C2 VIN TAG Placement
Re: C2 VIN TAG Placement
Which BRINGS up a good question which plate is install first, trim or vin. I thought the trim, but in this case looks like the vin. The weld on the left side of the vin would have made a mark on the trim tag. I never seen a vin that close to a trim, thats unusual but not impossible. Phil 8063- Top
Body 9611/VIN 19091 seems to fit; my info shows 9594/19051 as a fit & 9687/19272 also. But I have NEVER seen that location of the two tags. It may be time to get the Trim Tag book out and see if the car suddenly acquired leather, changed color or ?????- Top
Trim tag maches - paint, interior color are good. All other "tag" numbers appear to match: (1) Body Build Date = K2; (2) VIN=19901; (C) Body Style Numeric Sequence is 9611 - all indications of a late production car. My only concerns are (1) the multiple welds (although this is said to be not unusual), and (2) the placement of the tags (no space). I did find a photo of another "late" car with similar welds - photo attached here - but the placement shows the typical space between the tags in this example.Attached Files- Top
The VIN tag on my 63, which is also a 119,xxx serial number, has a 3/8" gap between it and the trim tag. The spot welds look smaller/neater, and I don't see any course grind marks or paint edge at the tag like in your picture. I would suspect a re-tagging which may explain the repositioning offset from original spot welds and the grinding, and perhaps touch up on the paint around the tag - but then, what do I know. Sorry.
Stu Fox- Top
My opinion is just that, only my opinion, but I would guess if this tag is original to the car, it has been re installed. I don't think it left the factory as shown. JMO.Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
