73 - L48 engine not started for long time - NCRS Discussion Boards
  • Joseph A.
    • August 31, 2006
    • 28
    I've had my car on jackstands for quite some time while I had the rear trailer arms rebuilt, struts rebushed, replaced brake lines, etc. Is there anything I should do to try and help lubricate the engine before I try and turn it over as I'm sure every trace of oil is in the pan by this time. Thanks for your help. Joe 46306
    • 11608
    Re: 73 - L48 engine not started for long time
    Joe,
    How long? Many of us up north go 6 months without driving our cars.
    If you're concerned, you can buy a "pre-oiler" or oil pump primer from a company such as Summit Racing. This is used by removing your distributor, and then using a hand drill with the pre-oiler to work your engine's oil pump. After a few seconds your oil is up to pressure and you're good to go.
    Patrick
    • Joseph A.
      • August 31, 2006
      • 28
      Thanks Patrick, I'd say 9 - 12 months I've had it up on stands. Joe 46306
      • Michael W.
        • April 1, 1997
        • 4290
        That's not long enough to worry about the oil. Prime the carb, turn the key and off you go.
        For reference, I witnessed a fleets of engine being torn down after three YEARS of inactivity. The bearings were still dripping wet.
        • Steven B.
          • June 30, 1982
          • 3976
          I was talking to a guy today who is taking a family car out of storage (it was just parked, battery, etc,. all still in it) after 7 years and said he is going to start it. Other than changing all fluids and filters what else should he do? The Camaro has a 350 in it I believe and is in a garage where it was parked all those years ago.
          • Oliver B.
            • February 1, 1992
            • 556
            My brother "just started" his 86 Vette after some 10 years of inactivity (I learned of that just afterwards - otherwise I'd told him to do differently, or at least be there to watch)... Astonishing enough that worked pretty well - unbelievable!
            • Joseph A.
              • August 31, 2006
              • 28
              Thanks guys for your replies. Sounds like I got nothing to worry about. Thanks again - Joe 46306
