When I bought my car I was told there was a rebuild done ~500 miles ago. It was running real rough and so my friend and I did a compression test on it. 5 cylinders had ~150psi and 3 had 0psi. I took the valve covers off and found a push rod missing for one intake and two push rods bent/broke for two other intake valves. I contacted summit thinking I would need a new cam, valves and push rods. I was told to just purchase three push rods and get the car running, which is what I want to do until I gather my parts for the frame off restoration. I was also told that I have a more performance oriented cam since the cylinder pressure is at 150psi. I was told it should be more at 200psi. Is this accurate? Why would three of my intake ports be bad? I am waiting for my fuel pump and sending unit to arrive, so I can get the car running. It did run on only 5 good cylinders. Where did the broken pieces of the push rods go? I bought a new gasket for the oil pan, thinking pieces may have made there way to it. I do not wish to do a full tear down yet, but I do not know what the previous owner considered a "rebuild", if it even had one. The push rods were not even the same, there was an odd ball shape for one of them.
Help
Todd
Help
Todd
