72 Headlight Actuator Markings - NCRS Discussion Boards
    • 6940
    does The Factory Put Any Marking On Actuators From Factory ,saw A 71 With What Look Like Red Marks On Each Facing Front Of Car.
    • 15573
    Re: 72 Headlight Actuator Markings
    Red dots on the actuator by the vacuum fitting that faces the rear of the car because the vacuum hose with the red line hooks up to that fitting. It helped the line workers to correctly install the correct vacuum hoses. Usually not on 1972s, almost always on 1970 and it seems to be less frequent on 1971. Relax and enjoy your Corvette.
      • 6940
      Thanks Terry For Your Response
