One of the old guys at the parts store I frequent suggested packing the cavity with wheel bearing grease, and a tight fitting dowel rod. Then smack the dowel rod with a hammer which will create sufficient hydraulic pressure to push the bushing out. Will this work?
Any other suggestions?
