C-3 Seat Tracks - NCRS Discussion Boards
C-3 Seat Tracks
  • Martin N.
    • July 30, 2007
    • 594
    C-3 Seat Tracks
    Can anyone out there tell me the secret of seperating the Lower (floor) side track from the Upper (seat) side track? I know there's a stop in there, I just don't want to "Bubba" it up trying to get the 2 apart.
    Thanks.
    Marty
    • 3415
    Re: C-3 Seat Tracks
    Hi Martin,
    There was a thread about seat tracks back in June of 2007.
    I believe there are some heavy rivets at the ends of the tracks that need to be drilled out to separate the two parts.
    I ended up restoring mine with the parts together. I was able to phosphate the 'feet' well enough with out removing the tracks.
    My tracks have what I assume is a nice distinct Julian date on them which I've never heard mentioned. My car a 71 was assembled in mid- January, 71.
    • Martin N.
      • July 30, 2007
      • 594
      Re: C-3 Seat Tracks
      ALAN-
      Interesting picture and info. Thank-you. I've lightly sanded my 4 tracks / adjusters at the same area that you provided the picture from and came up with these numbers; 2 @ 30207 and 2 @ 30219. These do not appear to be dates nor are these part numbers, which should be; L.H. #3996859 and R.H. #342218 as per the AIM and GM parts catalog. Any thoughts? Now I'm stumped.
      Marty
        Re: C-3 Seat Tracks
        Originally posted by Martin Novak (47651)
        ALAN-
        Marty
        Most likely those numbers are the supplier's internal part numbers for those detail parts; the GM part numbers in the A.I.M. are for the complete seat adjuster assembly.
        • Paul L.
          • November 1, 2002
          • 1414
          Re: C-3 Seat Tracks
          Does anyone have a picture of those rivets? I'm pulling my seats today for delivery to the upholstery shop tomorrow. Ideally I would like to refurbish the tracks at home, however. Hence things have to be separated. Like Marty I have a 1974 convertible.
          • Paul L.
            • November 1, 2002
            • 1414
            Re: C-3 Seat Tracks
            In the absence of a reply here (a Tech Board? Sometimes I wonder) I will let the upholstery shop do their job. The seats were dropped off there this morning.
            • Harmon C.
              • August 31, 1994
              • 3228
              Re: C-3 Seat Tracks
              I did not take the tracks apart. I have a tank I made that is long enough to just put them in the hot phosphate solution. The upper part may have changed color but it is not easy to see so I took the easy way out.
              Lyle
              • Paul L.
                • November 1, 2002
                • 1414
                Re: C-3 Seat Tracks
                Marty,
                I managed to get the job done. The Meguier's #40 dulls with time but still protects. I can't match the beauty of your 1974 but I am happy with the outcome.
                • Martin N.
                  • July 30, 2007
                  • 594
                  Re: C-3 Seat Tracks
                  PAUL-
                  Looking fantastic, job well done, hope it didn't set ya back too much. I like your "feet" buckets, where did you get them?
                  Marty
