1965-67 Reproduction Hood Latches - NCRS Discussion Boards
  • Carl R.
    • March 1, 1998
    • 166
    Good morning,
    Does anyone have experience with the reproduction 1965-7 "zinc-plated" female hood latches that mount on the firewall? Are they the correct plating/color, and properly-rivetted for judging? How about the male hood lock pins?
    I typically prefer used original (and my originals were beaded/clear-coated a decade ago), and am trying to decide if I'll be happy with these reproductions. If not, can anyone reccomend a good re-plater?
    Thanks for your time,
    Carl
    • 11608
    Re: 1965-67 Reproduction Hood Latches
    You're back!
    Long time no "see!"
    • Frank P.
      Infrequent User
      • January 1, 1992
      • 6
      Hi Carl, I recently used New Method Plating in Ma. Bill Wolf is the owner, great guy. Phone number is (508) 754-2671. I was real pleased with there work. Good Luck, Frank
      • Donald T.
        • September 30, 2002
        • 1319
        The differences I have noticed are in the tooling marks. Originals have parallel scratches all down the sides from manufacturing, which I don't see in reproductions. Also, the large adjustment screw that the hood bumper fits onto is different, but it is hidden. I don't recall a difference in the rivet. Also, the plating appears brighter on the reproductions. I have an NOS set and the plating is not as bright and reflective, but that could be due to age.
        • David L.
          Infrequent User
          • December 1, 2004
          • 7
          Carl, I have used the reprocuctions and had difficutly with the fit. As delivered mine would not allow installation of the upper bolt. The cure for mine was to tweak the two upper bends to allow the bolt hole to line up...replating is preferrable in my opinion.
