Stamped steeel valve cover paint - NCRS Discussion Boards
  • Ruud Z.
    • April 30, 2006
    • 69
    I have stripped my stamped steel valve covers ('63 327/300hp) both completely to the bare "steel". Do I need to apply a primer before painting ?? If yes which primer do you recommend. Obviously it will be hot under there.
  • Martin N.
    • July 30, 2007
    • 594
    Re: Stamped steeel valve cover paint
    RUUD-
    When I did my 74 driver approx. 2 1/2 years ago now I used the Dupli-Color high heat primer, lightly scuffed them with a Scotch Brite pad then painted with the Eastwood product. Looks good to this day with no peeling, rust or bubbles.
    Marty
    • Bob B.
      • March 1, 2003
      • 831
      Ruud,
      Since no one will know if you have primer or not, then do what works best. However, the valve covers were bare metal on the bare iron engine when the whole assembly was painted. The paint seems to hold up pretty well even with no primer.
      Bob
      • Geno B.
        • April 30, 2001
        • 90
        i have used por15 chevy orange with no primer and have had excellent results. be prepared to pay $18 for a pint though.
