Engine Mount Brackets - NCRS Discussion Boards
  • Tom H.
    • July 30, 2008
    • 49
    I purchased a set of engine mount brackets to replace the home-made brackets on my 57. I received two exactly alike, I think they should be different but I'm not sure if I have two driver side brackets or two passenger side brackets.
    Should they be different? and if so should they arc toward the front or back?
    Tom
    Re: Engine Mount Brackets
    Tom
    Tom-----
    The brackets are side-specific. My recollection is that there is a "notch-like" cutaway on the upper, inside corner of the brackets.
    • Gary C.
      Administrator
      • October 1, 1982
      • 17549
      Tom, the brackets arc from front to back. Frame bolt holes are closest to the radiator and the engine mount holes closest to the engine. Have a good photo if you'll post your e-mail address as am at max limit for posting photos on the TDB. Gary....
      NCRS Texas Chapter
      https://www.ncrstexas.org/
      • Roy B.
        • February 1, 1975
        • 7044
        Also remember you need to add shims to align the engine straight
        • Don Y.
          • July 31, 2000
          • 166
          Here is a pic of the R/S mount bracket on my '57, before the body drop.
          • Tom H.
            • July 30, 2008
            • 49
            Thanks to all.
            Please excuse my whiney post, I was hoping to get something done last night and was unable to because of the part. The vendor is mailing me a new pair. I'm sure it wouldn't be my last issue with mail order parts.
            Don's photo is great. Gary if you have others my email is ThomasHinds@sbcglobal.net
            • Roy B.
              • February 1, 1975
              • 7044
