Which side of the intake manifold should the wire from the temperature gauge to the brass temperature sending unit on the intake manifold be routed? On my 65 L79, the wire is routed on the driver's side of the intake manifold and held in place by two black phosphate clips connected to two top side valve cover bolts. I believe it should be routed on the passenger (right side) side of the intake manifold but I want to confirm this. Thanks.
65 L79 Temp Sending Unit Wire Routing
