6 volt LED lamps - NCRS Discussion Boards
6 volt LED lamps
  • Joe R.
    • July 31, 1994
    • 287
    6 volt LED lamps
    I really want to keep my 54 as stock as possible, but I ran across a product available now for those of us 6 volt guys that want a brighter tail/brake/turn signal lamp (for obvious safety reasons).
    Has anyone tried any of these direct plug in LED lamps?
    Joe Ryan
  • Stephen B.
    • December 1, 1984
    • 98
    Re: 6 volt LED lamps
    they are much brighter for the 12volt imagine you would get the same results with the 6volt set up the only problem i can forsee is there may not be enough current draw to make the flashers work i do not know if they have any real resistance built into them just my 2 cents Steve
    • Roy B.
      • February 1, 1975
      • 7044
      Joe Ryan
      I've seen no problem with stock bulbs ,but I would worry about the heat they generate on the plastic Lens .Just change the bulb amp.#
      • Stephen B.
        • December 1, 1984
        • 98
        leds produce very little heat compared to a regular bulb and are quite a bit brighter I would not be afraid of them I use them in my motor cycle and they are used extensivley in the auomotive field these days Steve
