I have a 71' 350/270 engine that is driving me crazy. When I first bought this car it ran very poorly at idle. It had low manifold vacuum (13") and would not idle no matter how you set the mixture. The exhaust smelled like raw gas. I gave several mechanics a crack at figuring out what was wrong. None of them could come up with anything except that the engine was tired and needed overhauling. I pulled the engine out and had it rebuilt. The engine was worn, and it needed to be rebuilt, as it turned out upon inspection. But now the engine is back in the car, and it still runs terribly at idle, reeks of gas and has 13" of vacuum, as before. It is not the carb. The carb was tested on a test engine and functions perfectly.
Everything else in that engine is new, except the castings. The machine shop says they inspected/magnafluxed all castings and found no cracks.
Right now I have all vacuum ports plugged and a gauge on the manifold tee. I have verified tdc of piston at 0 degrees. I have verified cam timing is correct. Ignition timing is set a 8 degrees btdc. I have tried spraying propane around the base gasket and the intake-to-head gaskets. What am I missing? Is it possible to have a crack in the intake somewhere else that could cause this problem?
