I am a newbie to Corvettes (just 1 year) and am trying to determine if I should do a body off on my 1960. The car spent the first 10 years in Texas then the rest of the time in California. It has about 125K miles and has just some light surface rust on the frame. The car appears to have been garaged most of its life. The only frame repair I think it will need is to repair two 1.5" X 4" sections on the bottom of the rear crossmember. There are a couple of reinforcement plates that size welded to the bottom edge of that crossmember. I figure I could repair that on the car without too much trouble in a few hours.
I saw a few postings recommending not to do a body off unless the frame was pretty bad and only if one had no plans to drive the car after the restoration. I have seen a website where a 1970 frame was restored while on the car and could do that instead.
The car was restored in the 70's and has shiny laquer with lots of clear plus some surface cracking in all the typical places. Aside from the engine, transmission, upholstery and radio it is original but could use a restoration so I can get it Flight judged. My goal is to keep driving the car even between judging events. It is more important to me to be able to drive this car than to win awards.
I was thinking the body off made sense so I can have my painter work on it for 6 months or so while I restore the chassis restoration. With a body off I plan to drop the body on partially assembled like the factory did it. In a month I'll have a correct engine long block back from the rebuilder as well as rebuilt T-10, restored manifold and dual carbs, new AK interior and restored Wonderbar. I have tried to buy original or NOS parts with all the correct dates to make it as original as possible and have followed the JM.
I have no plans to sell the car and could conceivably have it for the next 30 years or so and will probably drive it a few thousand miles a year.
The car has no mechanical problems I know of and drives great. If I don't do a body off then I'll spend the 6 months while it is being painted recovering the seats, restoring the gauges, restoring the hard top, rebuilding the generator and getting the power top system working. I plan to do this work myself. I would then do the frame restoration like was done for the 1970 mentioned above. I have been working on cars on and off over the last 25 years so I feel I can do much of this work myself.
Here are my questions:
1. does a body off makes sense ? If I mark and reinstall all the shims just as they are now will that de-risk this some ?
2. any issues with using one of those Nuair aluminum dollys ? I plan to transport the body on the dolly 100 miles to the painter's house. I like this dolly because I plan to disassemble it after and keep it for a future restoration.
3. if I do the body off does it make sense to send the chassis out for powder coating ? It would be nice to have a newly painted chassis.
4. since I do plan to drive it does a single stage enamel make sense versus bc/cc or acrylic lacquer for Sateen Silver ?
5. if I don't do the body off is it difficult to drop the engine and transmission into a freshly painted car ? I have installed several engines over the years in different cars and never damaged a body.
Mark
Mark
