Door Lock Knob removal - NCRS Discussion Boards
  • Rob M.
    • June 30, 1999
    • 171
    Are there any tricks for removing the door lock knob retaining clip? The knob is in a recessed area and the clip removal tool that works for the window crank does not work on the door lock. I have repo door panels that are painted and I don't want to mar the finish... The door panel seems a bit stiff in the area and will not depress enough to see the clip.
    Any suggestions will be appreciated. The car is a 65 coupe.
    Rob
    My Project Pictures
    http://temp.corvetteforum.net/classics/l78vetteman/
    Re: Door Lock Knob removal
    This has come up before and there are prior threads in the achives. Some use a L-hook hand tool while others grab the clip with a pair of needle nose pliers.
    You CAN gain working space access by pressing the door panel IN a bit...
