1967 front bumper - NCRS Discussion Boards
1967 front bumper
  • Jim W.
    • 1
    1967 front bumper
    I have a 1967 roadster, which seems to be very original. Underneath the front bumber on the outside of the lower bumber extensions are 2 phillips head bolts, approximately 1-2" below that, are 2 holes. Very symetrical approx. 3/8's in diameter One on each side. I see it on a lot of 67's. Is this correct?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 1967 front bumper
    Yes, That is correct.
    • Ray G.
      • May 31, 1986
      • 1187
      Hello;
      Additionally the rounded phillips head machine screws attach to brackets under the headlight support bars and should be painted the color of the Corvette.
      Hope this helps.
      Ray
      I hope you dance
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1464
        Hi Jim
        Now I'm confused.
        From your post, I thought you were referring to the two screws that attach through the lower valance to the core support, these were in position when the body was painted and are the same cross recess head as the upper and lower window track screws at the end of the door.
        Sorry, Ray. I'm not clear on your reference to the "brackets under the headlight support bars".
        HaND
        • Wayne W.
          • April 30, 1982
          • 3605
          Originally posted by Mike Murray (25129)
          Hi Jim
          Now I'm confused.
          HaND
          The L bracket goes under the HL support brace. The phillips head screw goes through the panel into the bracket.
          • Ray G.
            • May 31, 1986
            • 1187
            Hello Mike;
            Sorry, my description was lacking.
            Think Wayne cleared it up.
            Have a nice day also.
            Ray
            I hope you dance
