C1 Splash shields - NCRS Discussion Boards
C1 Splash shields
  • Terry K.
    • July 31, 1975
    • 82
    C1 Splash shields
    120854 bolt, 120392 P W, 120342 P W, 120380 L W, 134551 Nut, & 3659780 Screw.
    Where can I go to get a description of these so that I can get them locally. I suspect they are not anything special, but ...
  • Dan H.
    • July 31, 1977
    • 1365
    Re: C1 Splash shields
    Terry, best source you have is your car! Find the same bolt etc. in the AIM some where else on your car and presto, that's what you need back in you splash shields! Those same bolts are all over. Same part number bolt may have different 'head' markings but the size will be consistant with what was intended for each application. Happy Hunting!
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Ray C.
      • June 30, 2001
      • 1132
      If you have a Pargon catalog, they normally have a very good bolt selection as per application. You should be able to find type and head markings there. If you can not find the information, call them and talk to a Tech.
      Ray
      Ray Carney
      1961 Sateen Silver 270-HP
      1961 Fawn Beige 315-HP
      • Terry K.
        • July 31, 1975
        • 82
        Dan, Ray:
        Two very good suggestions. I have pursued both and have a good idea of what I am doing now!
        I appreciate it very much!
