I am about to replace the Hurst shifter in my 66 with a repro 4 speed shifter. I dry fit the linkages on a spare Muncie out of the car. The reverse linkage seems to have too little lateral offset between the transmission lever and the shifter arm. The linkage that came with the shifter has an offset of about 1 1/2" between rod centerlines and I seem to need about another 1/2" so that the end that fits into the reverse shifter arm is not cocked. I think I have the incorrect linkage. Can anyone confirm the offset dimension for a 66 reverse linkage? Otherwise the shifter unit seems to be well made. Thanks for any help
66 Muncie 4 speed Reverse Linkage question
Tags: None
- Top
Re: 66 Muncie 4 speed Reverse Linkage question
William------I am about to replace the Hurst shifter in my 66 with a repro 4 speed shifter. I dry fit the linkages on a spare Muncie out of the car. The reverse linkage seems to have too little lateral offset between the transmission lever and the shifter arm. The linkage that came with the shifter has an offset of about 1 1/2" between rod centerlines and I seem to need about another 1/2" so that the end that fits into the reverse shifter arm is not cocked. I think I have the incorrect linkage. Can anyone confirm the offset dimension for a 66 reverse linkage? Otherwise the shifter unit seems to be well made. Thanks for any help
The shifter levers which are part of the shifter assembly were the same for all 1964-81 Corvettes. So, even if you had the wrong shifter assembly (there were 3 used over the 64-81 period), the shifter levers which are part of each would work correctly (the shifter handle is the primary difference between the 3 shifter assemblies).
However, the shifter levers attached to the transmission and the shifter rods were different over the years. 64-67 reverse lever is different than 68 and later. And, the 64-67 reverse rod is different than 1968 and later. So, my guess would be that you have an incorrect transmission-mounted reverse shifter lever and/or reverse shifter rod.In Appreciation of John Hinckley- Top
Thanks,Joe. I have the correct reverse transmission lever, so it appears that the rod is the wrong one. I am hoping that someone can confirm the dimension of the correct offset before I order the correct rod. The Noland Adams has many GM shifter rod blueprints but not the ones I need.- Top
William,
I did the exact same thing a few years back. I got the repro form Long Island Corvette and it fit fine. If I get a chance tonight I will get a photo & post. I assume a direct shot from the bottom will show what you need?
Brian66 Coupe
66 Convertible
2022 2LT Coupe
67 Chevelle SS396
67 XLCH HD Sportster- Top
Brian, Yes a photo from underneath showing the reverse linkage will be very helpful. Thanks!- Top
