Door jamb paint - NCRS Discussion Boards
Door jamb paint
  • Kirk M.
    • June 30, 2006
    • 1036
    #31
    Re: Door jamb paint
    Originally posted by Mike Murray (25129)
    Kirk, I believe (and hope) you meant "Trim Tag".
    If you have in fact replicated the Typical Factory color, material and application, you should not receive originality deductions.
    HaND
    Mike,
    My bad. I hate the brain farts that come along with age. Yes, clearly I meant trim tag.
      Re: Door jamb paint
      Originally posted by Michael Hanson (4067)
      Last year, John Hinckley joined one of these discussions that I had going and said that the point on the assembly line where the tabs were painted was, I believe, the final trim line.
      Where required as Michael pointed out above, the dash end tabs were masked and painted in Final Paint Repair, which was after the car came off the Final Line (with no interior soft trim in it), and before the Final Trim Line (which is where all the interior soft trim was installed).
      • Michael H.
        • January 29, 2008
        • 7477
        #33
        Re: Door jamb paint
        Thanks John. I'd like to add one thing to that. The only thing that was masked/shielded when the dash end tab was shot was the side of the dash pad.
        That explains the overspray on the interior light switch. It also explains the dry spray around the dash tab.
        • Andy F.
          • January 1, 2004
          • 93
          #34
          Re: Door jamb paint
          If it were me and only wanted a dull finish for judging, or until it is determined that gloss was correct, whatever I did I would want it to be temporary. I'd try lightly spraying hair spray on the door jambs. It will wash off it you dont like it.
